Inventor Forum
Inventor vs SW for bend allowance
12 REPLIES 12
Message 1 of 13
372 Views, 12 Replies
I did a simple bent up part in Inventor sheet metal by starting with a flat
plate,adding flanges and finally adding holes to each face. I then developed
the flat pattern and used this flat pattern in an idw with ordinate
dimensions for the holes from a set corner. I also used the flat to show the
bend centers and specified an inside radius for the bends. Ok simple Simon
stuff but when I sent it out to one of our vendors to be punched and bent
they called back and said the bend allowances and the flat pattern did not
jive with the drawing....what?! Turns out that when their engineer (who uses
SW) did a solid from my flat pattern and bent it on the lines I spec'd using
the same inside R that I used that things didn't work out. I have always
used the default K factor in Inventor sheet metal and everything has always
turned out exactly as the model when it's built in the shop, so what gives
here???? He did say that he uses K factors they load in from a spread sheet
into SW but there should not be more than a couple of thousands difference
should there?
Albert
12 REPLIES 12
Message 2 of 13
Albert,
Actually based on experience I had with SPI, Radan AutoSM and ProFold in
MDT, and now experience with Inventor there can be a significant difference
between parts that use different Kfactor or Bend allowances.
Many different people have their own variation on Kfactor and how it is
calculated. Inventor Kfactor is close to what I experienced in our own shop
but it doesn't take into account Sheetmetal material, and V-die sizes. It
is only based on 0.44(44%) offset of the neutral bend axis, which for most
situation is close but for others, can create a big difference (.010 - .05,
or more) per bend difference.
Stan McLean
"Albert Allen" wrote in message
news:66487808A1CE2C0C8F2870B46C4E70F2@in.WebX.maYIadrTaRb...
flat
developed
the
uses
using
always
sheet
> should there?
> Thanks,
> Albert
Message 3 of 13
welcome to sheet metal. i used to use pro/e's sheet metal package when i was
in the sheet metal field. i remember that they used some thing like R-FACTOR
or some thing like that. it was loosely based on the K-FACTOR. this default
setting didn't jive with our tried-and-true bend allowances out in the shop.
we used v-dies for all our breaking. we pretty much learned how to fudge our
models so the flat pattern would come our perfectly for our machines. pro/e
was just like SW and Inventor though. you were able to make a custom bend
allowance chart in xcel. we just never used that feature.
i'll tell you this though. bend factors are ALWAYS different for every shop.
i still regard K-FACTOR as reference only. let the shop guys tell you what
your bend allowances are. with that info and a little trial-and-error you'll
get it right every time.
Mark A. Bystry
Engineer
Ziggity Systems, Inc.
mbystry@ziggity.com
Message 4 of 13
Thanks Stan,
I guess the best way is to have each vendor send us their K factors for
their dies and use them, the only problem with that is we would have to make
different drawings of the same part for each vendor (purchasing loves to
bounce around for the cheapest price). As my old boss used to say "were
building tractors here not rocket ships"
so maybe it's just not that important
"Stan McLean" wrote in message
news:B33E90BBC1D49BCC2F288EF05E7FA479@in.WebX.maYIadrTaRb...
> Albert,
difference
shop
.05,
> Stan McLean
> flat
> developed
> the
Simon
bent
not
> uses
> using
> always
gives
> sheet
difference
> > should there?
> > Thanks,
> > Albert
Message 5 of 13
The guy at the particular shop that had questions about our bend allowances
says they like to get the finished piece drawing (no flat pattern) and they
developed their own solid and do the flat. Is this normal operating
procedure for most sheet metal shops? If so it would be easier for me.
"Mark A. Bystry" wrote in message
news:D6CC3AEFE319C24C2AC238E8C1EC8344@in.WebX.maYIadrTaRb...
was
R-FACTOR
default
shop.
our
pro/e
shop.
you'll
> Mark A. Bystry
> Engineer
> mbystry@ziggity.com
Message 6 of 13
It is what the shops I have dealt with prefer.
Kent
Member of the Autodesk Discussion Forum Moderator Program
news:72D87C6F56DA370D08C338D8034C80A9@in.WebX.maYIadrTaRb...
Message 7 of 13
If you send itoutto be done let them find the flat they need don't supply it. If you do and it is wrong they put the blam on you if you send then what you want in finished dim and it is wrong its at there cost not your's
Message 8 of 13
That's the case for the few Sheet Metal fabricators I work with.
I won't flat pattern unless they really beg.
Richard
Message 9 of 13
If they realy want one tell them you want the bend deduction they use the radius and the bottom v dim. and have them check the flat before production.
Message 10 of 13
As well as most of the ones I deal with. I prefer it this way as I want the
finished product. I could care less what the flat looks like...(of course
if you do sheetmetal in-house it's a different ballgame)
Sean Dotson, PE
http://www.sdotson.com
...sleep is for the weak..
"Kent Keller" wrote in message
news:3B7DCA59ACEDC726DB1A8EAC5663869B@in.WebX.maYIadrTaRb...
> Kent
allowances
they
Message 11 of 13
That's my experience. I've never supplied a flat pattern. I just show
exactly what I want the finished part to look like, and let them figure it
out. Maybe in a big operation, where the sheet metal is done in-house, the
flat pattern would be useful. Or, if the sheet metal shop was using
Inventor, they could make use of this portion of the tool.
Keith
allowances
they
> was
> R-FACTOR
> default
> shop.
> our
> pro/e
bend
> shop.
what
> you'll
> > Mark A. Bystry
> > Engineer
> > mbystry@ziggity.com
Message 12 of 13
Albert:
Don't get me wrong on my comment about avoiding supplying flat patterns
like the plague.
Once in a blue moon, I've asked for sheet metal parts that aren't normal
and the fabricator throws in the towel and admits he can't figure it
out. In those rare cases 'Flat Pattern' makes me look like the genius I
wish I really was. Oh yah!
Autodesk, don't interpret this thread as an excuse to stop improving the
Sheet Metal application.
Richard
Message 13 of 13
Albert you need to remember that there is also the difference between bottom
bending and air-bending and the different V-Dies. On some materials I have
14 different k-factors. At least you can have them all in one template and
can choose between them my sheet metal template has over 200 styles. That is
over 200 k-factors welcome to sheet metal
flat
developed
the
uses
using
always
sheet
> should there?
> Thanks,
> Albert
