Inventor Forum
inventor view object missing in excel
8 REPLIES 8
Message 1 of 9
skyngu
807 Views, 8 Replies
hi,
I don't see inventor view object in excel's object list. I see it before I install solidworks. Is it related? even I dont think so.
How can I get "inventor view object" back into excel's object list? I want to insert it into excel sheet.
I am using inventor 2012 sp1, window 7 sp1 & excel 2007. thanks a lot.
Autodesk Inventor Professional 2019
8 REPLIES 8
Message 2 of 9
MariaManuela
in reply to: skyngu
From Help:
Register the InventorViewCtrl.ocx file in a command window if this is the first time you are embedding Autodesk Inventor View.
  1. From the Windows Start menu, select Run.
  2. Type "command" or "CMD" in Windows NT, Windows 2000 or Windows XP to start the command window.
  3. In the command window, navigate to the following location assuming that Autodesk Inventor View is installed in the default location (C:\Program Files [(x86)]\Autodesk\Inventor2012\Bin) and type 'regsvr32.exe InventorViewCtrl.ocx', and then press Enter.
http://wikihelp.autodesk.com/Inventor/enu/2011/Help/User's_Guide/119AutodeskInventorVie/3211Collabor...
Asidek Consultant Specialist
www.asidek.es
Message 3 of 9
skyngu
in reply to: MariaManuela
I follow instructions from help before I go to forum. It did not help.
Message 4 of 9
skyngu
in reply to: skyngu
is this a bug for inventor 2012? or just me. thanks
Message 5 of 9
MariaManuela
in reply to: skyngu
I could see that it is the same with me and I do not have the solidworks. I do not know if it's bug.
www.asidek.es
Message 6 of 9
skyngu
solidworks???
Message 7 of 9
MariaManuela
in reply to: skyngu
@jcneal wrote:
hi,
www.asidek.es
Message 8 of 9
skyngu
oh ok. thanks for your reply.
I tested it on a machine without installing solidwork. same error happened.
Message 9 of 9
mecheng
in reply to: skyngu
I have the same problem and put in a ticket to Autodesk I believe this is a bug. I have also tried to register the ocx file as an administrator and non administrator. Doing that did not update the list within excel for me, so right now im at a loss.
