hi,
I don't see inventor view object in excel's object list. I see it before I install solidworks. Is it related? even I dont think so.
How can I get "inventor view object" back into excel's object list? I want to insert it into excel sheet.
I am using inventor 2012 sp1, window 7 sp1 & excel 2007. thanks a lot.
From Help:
Register the InventorViewCtrl.ocx file in a command window if this is the first time you are embedding Autodesk Inventor View.
I follow instructions from help before I go to forum. It did not help.
I could see that it is the same with me and I do not have the solidworks. I do not know if it's bug.
@jcneal wrote:hi,
oh ok. thanks for your reply.
I tested it on a machine without installing solidwork. same error happened.
I have the same problem and put in a ticket to Autodesk I believe this is a bug. I have also tried to register the ocx file as an administrator and non administrator. Doing that did not update the list within excel for me, so right now im at a loss.
