Inventor Forum
Inventor View 2013 silent installation
1 REPLY 1
thomas_010
2374 Views, 1 Reply
I have a problem to deploy the 2013 Version of Inventor View. (german)
To install the application i use the msi file which is stored in the folder "x86\inventorview\" in the installation package.
This works after i delete one row in the msi file with the tool "orca". (removed the exe launch condition)
When I try to start the application after the installation, I receive the error "ApprenticeRegSvr has stopped working".
After this error message I recieve "Inventor View stopped working".
I was able to deploy the 2012 Version successfully and use the same procedure for 2013.
When I install the application with the setup.exe it works.
(I also install all 3rd party applications which are required.)
Any ideas?
1 REPLY 1
klapproth
in reply to: thomas_010
Same problem here. It seems the UI-less installer misses some files. I manually copy the missing files per GPO.
From autodesk_inventor_view_r2013_german_win_64bit\x64\de-DE\InventorView\Program Files\Autodesk\Inventor 2013\Bin\Bin32\de-DE copy SrvRes.dll , UTxRes.dll , RSeRes.dll to %ProgramFiles%\Autodesk\Inventor View 2013\Bin\Bin32\en-US
Copy every file from autodesk_inventor_view_r2013_german_win_64bit\x64\de-DE\InventorView\Program Files\Autodesk\Inventor 2013\Bin\Bin32\de-DE to %APPDATA%\Autodesk\Inventor View 2013\Bin\en-US without overwriting any file (use target rule: CREATE)
