I have an .ivb File and IV loads this file on start, and crashes instantly.
If i change the startup file to an empty one IV starts and if I load the Project file manualy it crashes again
I know which line brings the crash but i cant edit the file to delete this line, so what can I do?
Solved by axi92. Go to Solution.
I checked my corrupt file into vault so I have an copy of that. But where can i bug report this file?
And yes I have SP1 ist there a SP2? Eventualy the SP2 works again to open it?
Can i remove just the SP1 so I can open it edit and reinstall the SP1? If so how can i remove the SP1?
Now i got the next problem after downgrading (removed all updates) and restart the computer.
I start IV and on the Splashscreen i got the Message:
AdLm kann nicht initialisiert werden. Meldung über internen Fehler: <Preptool wurde seit Erstellung nicht ausgeführt.> Fehlercode: <6>
What does it mean?
AdLm? License Manager?
Internal Error: Preptool was not executet since it was created?
Is there a service not running?
Another strange thing. Last week I was editing some of my VBA-macros in the VB-editor in Inventor. Changed some lines, saved the .ivb file, closed the VBA-editor and started using the edited macro's. So far so good. At the end of the day I closed Inventor. Next day started Inventor and it crashed on the splash-screen. From experience I know this has to do with the .ivb-file, so I replaced the last edited ivb-file with a previous backup, and it all worked again. Only problem is that all the editing was done for nothing. Yesterday I had to edit the .ivb file again, changed some lines of code, didn't save it in the VBA-editor, but instead I closed Inventor. Inventor then asked me if it was okay to save the changes in the .ivb-file on which I answered with yes. Then I restarted Inventor, again it crashed on the splash-screen. Come on, Autodesk, what's wrong here, and how can I solve this problem?
