Inventor General Discussion
justinvoltz2417
Message 1 of 5 (157 Views)
Inventor Vault 2012
157 Views, 4 Replies
11-07-2012 04:29 AM
Morning,
On one of our computers we've been having some issues with Inventor. It's crashing a couple times a day and when your working on a drawing on the hard drive and go to put it into Vault it says the panels are not in vault but they already are so it's wanting to double dip (see attached).
I've downloaded the recent updates and that hasn't fixed it. It's only his computer and seems to be specific to that folder. I tried just deleting the folder and and grabbing from vault but it did nothing.
I'm not sure what else to do aside from uninstalling then restalling. Has anyone else seen or herd of this problem before?
Justin
karthur1
Message 2 of 5 (149 Views)
Re: Inventor Vault 2012
11-07-2012 05:17 AM in reply to: justinvoltz2417
I think the workspace for that particular folder has been edited.
In Vault Explorer, browse to where the panels are.  Right click and chose "Get/Checkout".  In the Vault path column is this correct?
Under Vault Tools>Options menu, you can turn the working folders on so you can easily tell where the files are going.
justinvoltz2417
Message 3 of 5 (145 Views)
11-07-2012 05:24 AM in reply to: karthur1
Yup, already checked the file paths as to where they were going and everything is correct. I even hit yes to put them in vault and it doesnt because they already exist. What does not make sence is it's only the specific folder he's in.
Mark_Wigan
Message 4 of 5 (140 Views)
11-07-2012 05:35 AM in reply to: justinvoltz2417
sorry for the obvious question if you arelady sorted it, but are you guys all using the same ipj (inventor project file) ?
Ie, I would like to see your vault mapping for this ipj and set of Files. If that project file does not have the same mappings as when those files were first checked into vault Then vault will think they will be duplicates, not the exact same files.
best regards,
- Mark
(Kudo or Tag if Solved - it may help others)
PDSU 2015 Windows 8.1, 64bit.
karthur1
Message 5 of 5 (135 Views)
11-07-2012 05:41 AM in reply to: justinvoltz2417
... I even hit yes to put them in vault and it doesnt because they already exist.....
It doesnt put them into vault because you have the option to "Enforce Unique File Names"..correct?  or for some other reason.
In VE, browse to the folder where the panels exist.  Right-click>Go to working folder.  Does it take you to the correct folder in Windows Explorer?
Some screen shots would be helpful.
