Inventor Forum
Inventor Update Hung Up in Autodesk Application Manager
5 REPLIES 5
tdswanson
589 Views, 5 Replies
Hey everyone:
I have the Product Design Suite Ultimate 2015 installed and I use Inventor about 80% of my day.  I have an update that's been pushed down through the Autodesk Application Manager program and it's hung up in the Application Manager.  I open the application and there's a spinning wheel in there on the Updates tab.  It's been that way for a couple weeks and several reboots, but I can't get it cleared.
Since there doesn't appear to be a support area for that application, I posted here.
And for what it's worth, I logged into the subscription site and tried log a support ticket, but again, the first drop down asks you to select your product, and the application manager isn't in there.
Can someone help?
Thanks!
5 REPLIES 5
mcgyvr
in reply to: tdswanson
yeah.. don't feel too bad.. Its been quite flaky lately.. I'm sure they know about it and will address it with a fix sometime or another..
see attached.. notice mine says I need to install SP1.. but as you can see its already installed.. but application manager says not installed.
Also I've had that 3ds extension 1 listed for over a month now and it won't install either..
salariua
There is a bug in Application Manger. You need to uninstall it and install it again from here:
http://knowledge.autodesk.com/search-result/caas/downloads/content/autodesk-application-manager.html
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
tdswanson
in reply to: salariua
Here's what I did to resolve this issue:
* Uninstall the Application Manager through the Add/Remove Programs dialog box in Windows.
* Reboot
* Deactivate Anti-Virus software
* Right click on the installation file and choose "Run As Administrator"
* After the program installed, I rebooted again just to be cautious
* Open the Application Manager, and run any updates for Application Manager
* It found the Inventor update that was hung up before (SP1).  SP1 was already installed, but I ran the update and it apparently installed again successfully.
Thank you for your help!
salariua
I have reinstalled it but haven't touch update for the manager app itself, just the rest of them (inventor, 3d max, etc.). I figured if it's a bug I'll wait till next update!
Adrian S.
blog.ads-sol.com
tdswanson
I can't blame you for saying that, but just to be clear, I had this issue BEFORE I ran this update.  Good luck!
