Inventor Forum
inventor ultimate 2015 trial hangs up at main screen
8 REPLIES 8
Message 1 of 9
eman6398
1188 Views, 8 Replies
I have a subscription for the pdsu, but havent got my serials yet, so I installed the trial version of 2015. When I load inventor it gets to the main screen but hangs up as if it loading something. In the taskmanager the program isnt using anymore memory and is at a stand still. Is anybody else having this problem?
Dell t1700 Xeon 16 gb ram
Windows 7 64 bit
NVIDIA QUADRO K4000
Tags (3)
8 REPLIES 8
Message 2 of 9
DarrenP
in reply to: eman6398
its probaby the new home screen
go to big I>options>general tab>uncheck show my home on startup
DarrenP
Message 3 of 9
eman6398
in reply to: DarrenP
It locks up, I cant click on anything, but I still can move the arrow.
Windows 7 64 bit
NVIDIA QUADRO K4000
Message 4 of 9
eman6398
I found the fix in another thread.
http://forums.autodesk.com/t5/Inventor-General/Inventor-2015-Pro-My-Home-Startup-Freeze/td-p/4997544
Windows 7 64 bit
NVIDIA QUADRO K4000
Message 5 of 9
stevespath2625
I have had this happen on an install also.  I have turned off the home screen in applications options and all was resolved.
HOWEVER .. does anyone know what the root cause of this issue is?  I have several more installs and i would like to avoid this issue, we would also like to be able to utilize the new home screen to keep consistancy across the 18 seats currently in use.
Thank you for any assistance.
SWSpath
Sr. Mechanical Designer / Cad Administrator
Qualitrol Co. LLC
Message 6 of 9
Upon further investigation on this issue .....
I noticed that the install in question had the Fences program on it.
We uninstalled it, turned on the home window and rebooted, everything works fine now.
This may have solved this particular install but i am not confident i have determined true root cause yet.
SWSpath
Qualitrol Co. LLC
Message 7 of 9
Stevespath2625
DId you apply Inventor 2015 SP1..  This will resolve the issue.   It was reported at one time..  This issue was related to how anti-virus software was restricting the interface that launched the home screen.
Mark Lancaster
Message 8 of 9
funny you mention that i went, i downloaded the patches this morning and went to install on my system (which worked fine).
It seemed to lock up, so i rebooted and tried to install again ... no luck.
How long does this update take?
It has been running on my machine for 1/2 hour.
Started to worry about 2015, maybe should have skipped this one.
Message 9 of 9
This just keeps getting better 😞
My system was working fine but i installed the Service Pack and updates to verify they did not cause additional problems.
Well they did cause issues with my system.
They error messages i get are linked to the new home screen, i have turned off this feature in the application options and i no longer have an issue.
So the moral of the story is ... If it is not broke don"t fix it..
I have attached the windows that pop up when launching product.
error 1 comes up first, then error 2 and then error 1 comes back
once windows are gone you are unable to select anything on the home window except the x in upper right corner to close it.
Frustrating release for sure.
SWSpath
Sr. Mechanical Designer / CAD Admin
Qualitrol Co. LLC
