I am trying to constrain flexible hose in the Tube and Pipe routing portion of Inventor 2014. I am unable to get the nodes to constrain and when I do a positional representation my sweep fails because the hose isnt constrained. I did try to make the Origin planes visible within my Tube and Pipe assembly and tried to include geometry, but it will not work for me. Does anyone out there have any suggestions for me on this?
Welcome aboard!
Well, a lot depends on what you are trying to constrain from and to in your route. Do you use Auto Routes? Can you post a screen shot of what you're having difficulty with?
AutoCAD 2013; AuoCAD Electrical 2013; IV 2013 Professional: Tube and Pipe, Frame Generator, Content Center; Vault Professional 2013: Client, ECO
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
As a rigid pipe designer, I make sure my routes are all fully constrained to geometry, while still leaving at least one or more "legs" undimensioned to accomodate growth or shrinkage when there is the inevitable equipment layout change. This is much more important with rigid pipe than it is with flexible hoses.Underconstrain and you can lose your angles and corners and the route fails.... overconstrain and your route cannot grow or shrink when things move.... and the route fails. It's a discipline in finding the fine line.
Chris Benner
