Try the Showcase forum: http://area.autodesk.com/forum/autodesk-showcase/general/
Check Out this YouTube Video, It shows how to import more than 1 contstraint into Showcase.
http://www.youtube.com/watch?v=grOHD0l349g&feature=g-user-u
Hope That helps you.
Thanks for the reactions + link.
I will move over to the showcase section for my question.
I already had seen the given link but this will not help sins I already tried this several times.
I have this inventor file of an PC case that has more movable parts that has driven constraints.
For example: I have multi removable dust filters in this model that can easily slide out there brackets plus the top of the case can be removed. When I push the file from Inventor 2013 to showcase 2013 with only the driven constraint of one part it all works fine and triggers works great.
But when I select more than one driven constraint in inventor to push to showcase they will not work and sometimes they don't even been visible in the behaviour section.
What am I doing wrong?
