Inventor Forum
Inventor to Showcase
4 REPLIES 4
merlijng
332 Views, 4 Replies
I have this inventor file of an PC case that has more movable parts that has driven constraints.
For example: I have multi removable dust filters in this model that can easily slide out there brackets plus the top of the case can be removed. When I push the file from Inventor 2013 to showcase 2013 with only the driven constraint of one part it all works fine and triggers works great.
But when I select more than one driven constraint in inventor to push to showcase they will not work and sometimes they don't even been visible in the behaviour section.
What am I doing wrong?
4 REPLIES 4
blair
in reply to: merlijng
Try the Showcase forum: http://area.autodesk.com/forum/autodesk-showcase/general/
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
PaulMunford
I think that you can only bring through one constraint...
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
Doug_DuPont
Check Out this YouTube Video, It shows how to import more than 1 contstraint into Showcase.
http://www.youtube.com/watch?v=grOHD0l349g&feature=g-user-u
Hope That helps you.
Douglas DuPont
Inventor 2016 Pro, Vault 2016 Pro
Quadro M4000
Windows 10 64 Bit
merlijng
in reply to: Doug_DuPont
Thanks for the reactions + link.
I will move over to the showcase section for my question.
I already had seen the given link but this will not help sins I already tried this several times.
