Inventor Forum
Inventor to Showcase with Representations
4 REPLIES 4
HenrikGraversen
527 Views, 4 Replies
This should probably be a Showcase question, but I don't see any Showcase discussion Group.
I need to Import a IAM file with Views and Positions to Showcase. I found several tutorials on this, but
as soon as I add a position in Inventor none of the above are imported. Without any Positions, Views get Imported.
Any know why?
It's Inventor and Showcase 2013.
Henrik Graversen
4 REPLIES 4
-niels-
in reply to: HenrikGraversen
Don't have enough experience with showcase to help with your problem, but the showcase forum can be found here:
http://forums.autodesk.com/t5/General/bd-p/area-b163
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
I had the same issue and figured it out.
Follow these instructions
Open Showcase:
Click FILE, SETTINGS, IMPORT SETTINGS.
a dialouge box will pop up (Import Settings)
make sure the Import representation box is Checked
Click Close.
Then import your model.
Once the model is visible simple click a ( Alternative Lineups)
you will have all the Inventor information on the screen.
That saved me a ton of time.  hope it works for you.
If you have any isues you can e-mail me at igaspar@rsihomeproducts.com
I can send you screen shots if need be.
HenrikGraversen
That was one of the methods i tryed.
Don't work.
And i tryed again and again with diffrent iam's.
Henrik Graversen
I'm not sure, but perhaps it's a localization problem. I've had similar problems, and if I'm remembering right, switching Windows country settings (in Control Panel) to US English, showed Reps in Showcase.
Walter
Walter Holzwarth
