Inventor Forum
Inventor to Revit: Can't see model faces.
10 REPLIES 10
Message 1 of 11
pcrawley
733 Views, 10 Replies
I have a problem with getting an Inventor model into Revit.  It's not the import of the model that's the problem, but the way the model displays in Revit.  (It displays fine in AutoCAD, 3ds max etc - just not Revit.)
Here's the part file - it's just a simple box with a couple of split-face features on it to generate a pattern.
If I take the model into Revit, I can only see the pattern if I select the object.
Deselect the object and the pattern vanishes.  Here's an unselected/selected screenshot from Revit:
I'm posting this here in case there's a brilliant Inventor user who also has experience with Revit and may have seen this before.  (I'm also posting it on the Revit DG.)
Models attached - Inventor 2014 IPT and a SAT version of the same.
Peter
10 REPLIES 10
Message 2 of 11
DarrenP
in reply to: pcrawley
what about using the .adsk format?
to go from inventor to revit
DarrenP
Message 3 of 11
DarrenP
in reply to: DarrenP
nevermind its doing the same thing
DarrenP
Message 4 of 11
pcrawley
Cheers for trying!  Annoying isn't it.
This has been bugging be for days.  I'm at the point where I would willingly pay for a solution.
Peter
Message 5 of 11
DarrenP
its probably some revit setting we are missing
DarrenP
Message 6 of 11
pcrawley
I really hope so, but so far the Revit forum is very very quiet.
I have a few friends who are (in my eyes) Revit guru's - but so far they haven't found the elusive setting.
Peter
Message 7 of 11
DarrenP
i will try to get some other revit gurus to look at also
DarrenP
Message 8 of 11
DarrenP
i ran a check revit features report attached
split 1 & 2 are unsupported
DarrenP
Message 9 of 11
DarrenP
someone responded on your other thread here:
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Model-edge-display-problem/td-p/4350861
DarrenP
Message 10 of 11
Toth2012
The BIM exchange worked great for me in Inventor 2013 but in Inventor 2014 it is not working so well.  Please let me know if you find a fix.  You would think with all the extra buttons they added to Inventor 2014 for Revit that it would work better.
Message 11 of 11
pcrawley
in reply to: Toth2012
Find a fix?  For what?
This post was a very specific feature of the BIM exchange that wasn't broken as such - it just didn't do what I expected.  If you have a general question about BIM Exchange, then a new post might be more appropriate.
Peter
