Hello, I'm studying mechanical engineering at the University of Stuttgart (Germany) and I started learning by myself Inventor 2014. I got from the University the drawing template in A3 and A4 format, which we are using on our engineering drawings. I tried to use them in Inventor but somehow I can't get it right. I attached the A3 template, could you please help me with this one? Thank you.
Hi Curt,
you can set the dimension of your sheets like this:
For the border and the title block it's quite difefrent from Autocad, you can read a lots about it here:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-1C11B1C9-097A-4A8E-894D-8B0A94836AA7
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-97753A27-FCD6-4037-8DF4-E999A39783AE
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-1131497D-6618-4FCD-9028-02659E0E7BA7
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-0226E06E-86D4-4419-A82A-949B5B7C0E44
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-E8BD71BE-C90E-42FD-BCAB-4021498BDFF9
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-EDC5979D-F75A-4430-A4AE-F2260404C63E
I Hope that it can helps you!
Admaiora
In the link i posted before you can learn how you can create your own title block and your own boarder.
You can use Ctrl+C and Ctrl+V to copy your title block from autocad to Inventor during the creation of your title block.
Admaiora
