I have a completed drawing that needs to be with a different title block and maybe page size. Is there a way to swap this out without having to recreate the drawing on the desired format?
If the desired titleblock is already in the drawing it's a piece of cake. If not,... a slightly smaller piece of cake.
If it is in there, look at each sheet in the model tree and find the titleblock listed.
Right click on the titleblock and select delete. Now go above to Drawing resources, find the new titleblock, right click and select insert.
If it is not already there, open a drawing that has the titleblock you want. Find it in the drawing resources as shown above, right click and copy to clipboard. Now go back to the drawing you want in ti live in, right click on titleblocks in the Drawing Resources and paste. It is now available for insertion.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hi DanMcManus2492,
And if you end up needing to change the page size, simply right click on the Sheet node in the browser (Sheet:1for example) and choose Edit Sheet.
I hope this helps.
Curtis
