Inventor Forum
Inventor surface textures
6 REPLIES 6
8319 Views, 6 Replies
I have modelled a component in Inventor ready for tooling. The component is modelled as an Inventor Part, but in reality is to be pressed steel. I have now been asked to add a textured finish to the product. The texture is stone. My plan is to roll back the features to prior to my shell operation, add the texture details (probably a combinations of adding and subtracting material), then rolling forward the features.
My question is, is there a good method of adding such a texture?! I've tried through sweeps etc, but they all look very sunthetic and not at all natural or "real". I've also spent the good part of the day trying to find a way to bring the file through 3ds max and to mudbox to sculpt, but this is also proving troublesome... and I certainly don't like the idea of bringing a non-adaptive/parametric model back to inventor.
Any help would be great.
Throw some ideas out there and hopefully something will work!
6 REPLIES 6
mcgyvr
Just create a new color style and add a "stone" texture map or bump map to that color style. Then apply that color style to the part. No need to model a texture.
in reply to: mcgyvr
Sorry mate, but I need a physical texture in the surface as it will eventually dictate the tooling process.
mcgyvr
It is common practice to simply indicate required texture in the drawing. I've NEVER seen someone actually physically model a texture for a molded/stamped part.
One typically calls out the SPI or SPE standard in the print to dicate desired mold finish for injection molded parts. Or talk to your fabricator to discuss a suitable drawing callout to get the desired texture.
Never seen a "stamped steel" part with a "stone" finish though.. Are you sure this "finish" isn't just a wrinkle/textured powdercoat applied after fabrication or something like that.
in reply to: mcgyvr
Yeah, it is a unique situation, hence the trouble I've had trying to model the component.
Thanks.
rdyson
I have no idea what you doing so this is truely a shot in the dark
In Rhino (download the trial if you don't have Rhino) open the texture bitmap
Use heightfield to create a surface based on the bitmap's changes in grayscale
See if you can use the resultant surface in IV
PDSU 2016
in reply to: rdyson
Yep, I'm thinking that nurbs will be my only hope here.
