Hello!
This is going to be my first post here. I am gonna make it short but still try to put all information here. If I leave something out just tell me.
I've been useing inventor for 2 months now and I can handle the 3D and 2D quite good. I'm using inventor in my work. Problem is, I dont know that much about the options and customization in inventor.
My problem:
I started here on my work with 1 computer that they had here with Inventor on it. Styles,aplication options and templates is located localy on that computer.
Now we have 1 more computer here that we installed inventor on with same license. All projects are located on the server.
I'm going to work on both computer 1 and 2. (Not at the same time). This is because limited access.
So I want both computers to have same options and styles so there will be no conflict? What is the normal solution in this situation?
I really appreciate any help you guys can provide!
Solved by mdavis22569. Go to Solution.
Alright, that could problably work out!
I have got some questions doh.
Will i just copy the Design Data folder and put in on the server?
What will happen to all of the old projects on the server?
Does the Aplication options matter for your file? Or is that just for personal matter?
Thank you!
Okey! Thank you again Sir!
I'll try this, I just don't want to corrupt all other projects and files.
