Inventor Forum
Inventor Studio - Suppressing Translational Constraints
1 REPLY 1
dbcox
202 Views, 1 Reply
Hello everyone,
I am working on an Inventor Studio animation and have noticed a problem.  It appears that it is not possible to suppress/enable translational constraints.  My assembly has a translational constraint that I suppressed in order to “explode” the assembly.  I am animating the assembly process.  Once it is put back together, I need to enable the suppressed translational constraint in order for the model to function properly.  Am I missing something, or will I need a work around?
I thought about recording two animations and then splicing the two videos together, but I am worried about the transition.  I really need it to be a smooth transition in order to work.  Any ideas?
Thank you,
David
1 REPLY 1
dbcox
in reply to: dbcox
Got it!  I was able to substitute a tangential constraint.  It works fine now!
