Hi
In Inventor studio (2012) after modelling a part, when I go to render the part, the only options I get for 'render type' is illustrated or shaded.. Im sure I used to get several others, including realistic.. where have these options gone?! Or am I going crazy?
Jamie
Solved by mcgyvr. Go to Solution.
by render do you mean in the studio environment? If so all you get there is shaded or illustrated. The other options like realistic are for in the regular environment (not studio) under the view tab (visual style flyout)
I'm using Inventor 2012 and the Realistic option in the dropdown menu of the Render Image window, in Inventor Studio has also vanished. And the option does exist, see the rendering tutorial attached. Does anyone know how to fix this?
Regards
Brian
