Inventor Forum
Inventor Studio animate light
27 REPLIES 27
Message 1 of 28
Sweco
1139 Views, 27 Replies
Does anyone know if it is possible to animate a lightsource in Inventor Studio?
I have tried the "animate component", but it doesn't seem possible pick/attach lightsources...
/T
27 REPLIES 27
Message 2 of 28
in reply to: Sweco
Do you mean, so that the light moves, or that the light turns on/off?
Mike
wrote in message news:5122855@discussion.autodesk.com...
Studio?
/T
Message 3 of 28
Sweco
in reply to: Sweco
I was planning to move a light simultaneously with the camera in order to create a "camera flashbulb look", but I'm also interested in turning light on/off.
/T
Message 4 of 28
in reply to: Sweco
For release 10 & 11 you cannot animate light movement. It is most certainly
on the list of things we want to do.
Bill Bogan Product Designer - Inventor Autodesk, Inc.
wrote in message news:5123581@discussion.autodesk.com...
on/off.
/T
Message 5 of 28
Josh_Petitt
in reply to: Sweco
Bill, when are we going to get nested lights? This is all that is needed because you can animate the location of a sub-assembly.
We REALLY need nested lighting (i.e. lighting defined in a sub-assembly can be propogated up into top-level assembly). We design furniture and store fixtures and the lighting is a very important aspect of the design. We use the same light fixtures and bulbs over and over, but it is a MAJOR hassle to put 10 lights in the top level assembly to represent mini track lighting. It would be very nice to define the light location/properties for a particular light fixture once, then those properties can be used in a top-level assembly.
Message 6 of 28
Sweco
in reply to: Sweco
Thanks for your answer Bill.
A thing for the wish-list would be to have an option to the "camera" to include a "flashbulb" to it. (I've seen this in Microstations image rendering module)
/T
Message 7 of 28
in reply to: Sweco
We're well aware of the need Josh..., thanks for adding your voice to the
throng. Not sure when it will happen.
Bill Bogan | Product Designer - Inventor | Autodesk, Inc.
wrote in message news:5124199@discussion.autodesk.com...
top-level assembly.
Message 8 of 28
in reply to: Sweco
Are you looking for a burst of light at a specific time?
wrote in message news:5125001@discussion.autodesk.com...
rendering module)
/T
Message 9 of 28
in reply to: Sweco
IMO lights animation needs to cover
1) Animation of intensity / colour (i.e lights fading in or out, switching
on/off or changing colour like a 3 colour led)
2) Animation of position of lights... So a spotlight could rotate round to
highlight objects.
Regards
Rory
"Bill Bogan" wrote in message
news:5176957@discussion.autodesk.com...
rendering module)
/T
Message 10 of 28
in reply to: Sweco
In addition to animating light...
- Color
- Intensity
- Position (all aspects)
- On/Off
I would like to see:
- standardized luminence values (lumens, candela, etc.)
- predefined settings for incandescent, flourescent, etc.
- assignment of these values/settings to objects - so I could make lighted
objects
- simulate vehicle interior & display lighting
You get the picture...
"Rory" wrote in message
news:5177267@discussion.autodesk.com...
highlight objects.
Regards
Rory
rendering module)
/T
Message 11 of 28
robtupa
in reply to: Sweco
Bill,
I am looking for exactly this. I want to show a light strobing for a camera. Can I do this in 2008? I don't have it installed yet and it says nothing in the "What's New" literature.
If I can do this in 2008, I may just have to move up my install time.
Robert
Message 12 of 28
in reply to: Sweco
Inventor Studio 2008 does not yet support animation of lighting. It remains
on the list of enhancements. While I haven't tried it, I wonder if you could
"model" a physical strobe by placing a rotating aperature between a spot
light and your primary object of focus?
Gary R. Smith
Autodesk Inventor Team
Portland, OR
2.33GHz 2GB IBM ThinkPad T60p; XP pro SP2
ATI Mobility FireGL V5250 driver: 8.293.1.0
Message 13 of 28
Josh_Petitt
in reply to: Sweco
What about nested lighting? Is it supported with '08
Message 14 of 28
R.Corriveau
in reply to: Sweco
"physical strobe by placing a rotating aperature between a spot light and your primary object of focus?"
Great idea Gary. Maybe instead of rotating ,(angles are no fun) how about using a shutter so to speak. I picture a box or lamp shade with a front panel and set the panel to instant fade off and instant fade on? Naturally there would need to be a slight duration between. Message was edited by: Rick Corriveau
Message 15 of 28
in reply to: Sweco
> Great idea Gary.
Seems like it should work, but I haven't had a chance to knock together a
test scenario.
Message 16 of 28
JDMather
in reply to: Sweco
>(angles are no fun)
I think I would try the angle idea first - I don't think for this particular use that a driven angle constraint should be an issue.
Message 17 of 28
R.Corriveau
in reply to: Sweco
Probably not. My only other concern with the turning apature is there could be a sweep of light/shadows across the scene. I guess if it's fast enough you won't see it.
I haven't tried it so it's all speculation
Message 18 of 28
in reply to: Sweco
I just built a mechanical strobe in a "room" focused on a piece part.
Works just fine...
I'll post my clunky render - proof of concept in a bit.
Gary R. Smith
Portland, OR
Message 19 of 28
in reply to: Sweco
I created a "light box" with a revolving plate "aperature" and I modified
the lighting style by adding a light which I placed at a point "inside" the
box that was targeted at the part. I turned off the other lights in the
style (so the animation is pretty dark until the light is projected on the
object).
I only did three revolutions over a thirty second period - to verify that
conceptually this works.
You'd likely want other lighting in play and I suspect that you'd want a
higher "strobe" rate.
Message 20 of 28
in reply to: Sweco
[img src="@154703"]
