Inventor Forum
Inventor stoped working
1 REPLY 1
196 Views, 1 Reply
Hello. I am using Autodesk inventor professional 2013 (student version) and whenever i press create 2D scetch or i press mouse wheel button it stops working (drops me a submit an error window). i tryed to reinstal it for many times and it started to work for a single time (when i close the program and start it again it stops working again). But afted some time reinstalling program did not helped anymore. Now I can't use my inventor. I also tryed to install updates but it didn't helped. I laptop is powerful enough to run a program. Did anybody had same problem? Please help me.
Tags (1)
1 REPLY 1
blair
Did you follow the pre-requisites for installation:
1.) Logged in with Administrative Privileges
2.) UAC slider set to lowest position (UAC turned off)
3.) Anti-Virus software disabled.
4.) Current on all Windows sp's and hotfixes
5.) .NET 4.0 is installed on your system
6.) Your system meets the Autodesk hardware requirements (minimum specs)
The last three points are assuming Windows O/S as all you have posted is you have a laptop
You may need to do a clean install of Inventor. You can find the Clean Unistall Tool here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14893355&linkID=9242018
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
