Inventor Forum
Inventor Sping creation Issue
2 REPLIES 2
weiloon
404 Views, 2 Replies
Its about the extension spring created by Inventor.
No matter using the spring feature in design accerelator or coil feature, i am unable to create the spring wire of the coil touching each other, that means no gap in between. ( refer to the attachment)
In actual, the turn of the spring is touching each other.
In Inventor case, I cannot prepare technical drawing basing on the solid I created in Inventor, it will be longer than actual and the pretension of the spring is gone if there is a gap between the turns.  It means, if spring were produced base on Inventor’s drawing, the  tension will be very very low then actually intended for.
Can you have a look and let me know how to overcome this problem
At present,If I use MDT to create the spring and generates tech dwg. The MDT allow the turns to touch each other (that means no gap).
2 REPLIES 2
blair
in reply to: weiloon
You should be able to create a coil with a very small gap 0.000001 or smaller between the coil surfaces. The problem is with self-intersecting sweeps (coil) and surface contact. This small amount should still allow for the coil/sweep while being small enough not to affect your main dimensions.
This used to be a problem before the "Split-Surface" command, where we had to create a slightly different surface size to only apply a finish such as a Knurl to a specific area/region.
Delta Tau Chi ΔΤΧ
weiloon
in reply to: blair
Thanks for your reply.
Smiley LOL
