Inventor Forum
Inventor Simplify .. Distances/Model changes from Inches to CM
9 REPLIES 9
Message 1 of 10
mdavis22569
464 Views, 9 Replies
Curious if anyone else has had this issue. I'm UTD on all my patches/packs. I took an assembly and saved it as an IPT Simplify part. Using the Standard template.. did some measuring to make sure everything was ok and it was all in CM's. (Correct though) I then took the same assembly and saved it again ..but this time in the Sheet Metal default template just to see what would happen and it stayed in inches .....
Mike Davis
9 REPLIES 9
Message 2 of 10
mcgyvr
in reply to: mdavis22569
If you open your standard tempate and go to.. tools..document settings..units ..  what is the document units?
Message 3 of 10
mdavis22569
in reply to: mcgyvr
it's set to Inches .. but changes once it makes and saves the file to CM ... Not sure if it's a bug ... or what. However I don't have to worry about changing the units ..or worry about the other guys here changing the units if they just use the sheetmetal as a work around for now. We have a new EM ..and everything has to be perfect or he complains that SW does this ..SW does that ... I just wanted to see if anyone else had this unit change without them actually being the one to change it..
Mike Davis
Message 4 of 10
mcgyvr
I have verified that when using standard.ipt with simplify it changes document units to CM and when using sheetmetal.ipt the document units stay in inches..
You found a BUG!!! Squish it 😉
Message 5 of 10
mdavis22569
in reply to: mcgyvr
lol ..... thank you for confirming too ...now I can say it's not just me or any of the machines here. I'm sure I'll be asked for a data set next from them Now to get someone to report it too .. I put it on the Lab forum for Simplify too....
Mike Davis
Message 6 of 10
mcgyvr
It has been reported..
For your future reference..
I use this form.. and Steve Dennis or one of the other guys watch those all the time..
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Message 7 of 10
SteveMDennis
in reply to: mcgyvr
OK whoa. There really is no need to double report these things. We have multiple developers and QA watching the newsgroups. The feedback email form that is above is used by people who don't know about the newsgroup or don't access them. If you report it in both places you're going to mess us up! :-) As Mgyvr has done in the past, if you don't feel like anyone has replied to your NG post you can kick us via the feedback form but I can't wade through many more feedback emails than I do now, especially for duplicates. Use diligently please!
Steve Dennis
Sr. Principal Engineer
Inventor
Autodesk, Inc.
Message 8 of 10
mdavis22569
in reply to: SteveMDennis
I didn't see his post when I was on the Simplify forum ...sorry ...
Mike Davis
Message 9 of 10
I have quite a large assembly i want to simplify, but when i come to do this it doesn't show any templates available in the template box. i've tried creating them but the still don't show in the box. does anyone one know how i do this?
Thanks.
Message 10 of 10
JDMather
in reply to: JordanCrabtree
I would have started a new thread for this problem description as it doens't seem to be anything like the problem description in the original post.
Do you have your templates in the standard location?
Are you using projects with templates path pointing to a location other than the default location?
Have you installed the Service Pack and Updates?
Click on the white page (Browse Templates) and post screen shot of the resulting screen here.
The CADWhisperer YouTube Channel
