Inventor Forum
Inventor-Siimulation CFD
5 REPLIES 5
rschnureIV
421 Views, 5 Replies
Can parts modeled in Inventor be used in Autodesk SImulation CFD?
5 REPLIES 5
JDMather
in reply to: rschnureIV
Yes
rschnureIV
in reply to: JDMather
Will inventor parts import into Fluent software from Creare?
Robert Schnure
Mechanical Designer/Cad Coordinator
Mechanical Engineering
Tel.: (610) 524-5920 x 52251
Dir.: (610) 423-6251
Toll free: (877) 243-9711
Fax: (610) 524-2443
SNC-Lavalin Project Services, Inc.
436 Creamery Way, Suite 100
Exton | Pennsylvania | United States | 19341
NOTICE - This email message, and any attachments, may contain
information or material that is confidential, privileged and/or subject
to copyright or other rights. Any unauthorized viewing, disclosure,
retransmission, dissemination or other use of or reliance on this
message, or anything contained therein, is strictly prohibited and may
be unlawful. If you believe you may have received this message in error,
kindly inform the sender by return email and delete this message from
your system. Thank you.
DonovanCox
It likely will, Ansys has had compatibility with Inventor for awhile. You may want to talk to them to find out if the version of Fluent you have is compatible with the version of Inventor you have.
JDMather
Keep in mind that Inventor will export neutral format files STEP and IGES as well as stl, sat, dxf, dwg and several others.
rschnureIV
Thank you
Robert Schnure
Fax: (610) 524-2443
