Solved by CCarreiras. Go to Solution.
I have both Inventor Professional 2014 and 2015 loaded on my computer but I am not able to open the files. I get the message Error reading RSe stream. Any thoughts?
Hi!
Version 2015
Unzip the file in one folder.
Close all Inventor.
Inside the unziped folder, double click the project file:"Tubo_Curva_HVAC.ipj"
This will open Inventor.
Open the assembly:"Tubo_Curva_HVAC.iam"
Open iLogic Browser
In tab Forms, click the form button
Choose your values and apply
Save the assembly (in tab Manage, hit rebuild before) and close assembly
Open Drawing... and that's it.
If you have more problems, tell me.
Hi Carlos
Gracias for the reply.
Material -
0.25 inch black steel
All faces to be welded
Upper elbow radius - 8 inch (203.2 mm)
Lower elbow radius - 6 inch (152.4 mm)
I am not sure of the elbows radius from the junction of the XY axis. Possibly 8 inch if the height of the 8 inch part of the elbow was 11 inches above the XY axis ((d=8 + r=3) = 11) or 12 inches (see below from commercial reduction elbow)
This 8 inch to 6 inch reduction elbow should be commercially available but I need to get the data into an Inventor file.
Commercial 8 X 6 Centre to end = 12
Being able to change the diameters, example 8 inch to 6 or 10 inch upper and 4 or 8 inch lower would be a bonus.
The other end of the 6" pipe meets with an 8 inch square, 3/8 inch, box tube at bottom angle of 20 degrees right side of vertical.
Another issue will be a flange that will go from the 8 inch square tube to the 6 inch diameter pipe. Butt welding the pipe into the box tube would work but the transition from square to round woud be better with a flange.
Best regards
David
Ulaan Baatar, Mongolia
I would be fine seeing an example using any sizes. I just want to learn how to create the elbow.
You are welcome!
@travis.turnbow25 wrote:
Thanks so much Igor, this worked wonderfully!
Good day
Will AutoDesk Inventor Sheet metal do a development like this ?
https://www.fastcam.com/fastshapes/layout-lobster-pattern-development-for-metal-fabrication.html
Reducing from inlet dia to outlet dia
Regards
Hi , I has a quick look at your CADWhisperer youtube channel , impressive !
Do you have a video of a "Inventor sheet metal reducing elbow" similar to :
Regards
