Inventor General Discussion
Active Contributor
prajwal
Message 1 of 4 (281 Views)
Inventor Sheet Metal Issue.
281 Views, 3 Replies
01-03-2014 07:36 AM
Hello Everyone, I am making this 3d Model out of Sheet metal but I am having a problem finishing it. On the very bottom of the part, I want the red and the green surface to be parallel to the Y-axis on both sides. The sketch "Desired Geometry" shows what I am trying to make. I tried using corner seam but it gives me error. The distance between the two red surface can vary. Any suggessions on how this shape can be acheived which will give me a correct flat pattern too.
Thank You
Why not just create as a face? Maybe I'm missing what you're wanting to do. Take a look at what I did here and tell me if this is what you were going for.
chad38
Message 2 of 4 (252 Views)
Re: Inventor Sheet Metal Issue.
01-03-2014 08:25 AM in reply to: prajwal
Cybertron PC
Intel Core i5-3470 CPU @ 3.20 GHz 3.60 GHz
16.0 GB RAM
Windows 7 Professional 64 Bit
3D Connexion Space Pilot
Inventor Professional 2014
Autocad Mechanical 2014
Active Contributor
prajwal
Message 3 of 4 (224 Views)
01-03-2014 10:41 AM in reply to: chad38
Thank You. It was exactl what I was looking for.
chad38
Message 4 of 4 (220 Views)
01-03-2014 10:52 AM in reply to: prajwal
Great, glad to help.
Cybertron PC
16.0 GB RAM
