I am getting the attached error when trying to save a part. Anyone have any ideas?
Either the part file is corrupt, as the error message suggests, or perhaps your path name is too long in your environment, which you didn't tell us anything about. This shouldn't be a problem for a straight Windows environment, but other components of a network/server system may have limits.
Try saving the file to your local desktop, just to see if it's a corrupt file, or something else.
Windows 7 64 bit...Inventor 2013
Problem was solved...It seemed an emboss was causing the problem. When the EOP line was above the emboss it saved. When the EOP line was below the emboss it would not save. Altering the emboss fix the problem.
