Using Routed Systems in the Tube & Pipe Authoring dialog page on the
End Treatment pull down -- is there a detailed list of what
the different end treatments mean ? such as what does "Quick Connect"
exactly mean, or Swaged, single ferrule or dual (such as used with a
Swagelok fitting)... What can you do with "Other".... etc..
Well, with the way that we do our hoses, I have to place some custom fittings on both ends of the hose. I went through and made sure that both the hose and the fittings have the "ND" and "SN" parameters (these are both iparts that get published to content center by the way) that was suggested and the style still will not save. I know that I have to be missing something which has led me to try to get clarification on the male, female, and neutral connections. Or maybe I have the end treatments set up wrong. On both I have the end treatments set to "hose - permanent" (of course I have not be able to find any explanations on the various end treatments). On the types, I have the hose set to "hoses" and the fitting set to "hose fittings".
