I am bulding a glass cylinder and would like to add a door on the top edge. Is there a way to cut a section of the part out and then use that cut piece as the door?
Hi! It looks like you use Extrusion Cut to create the cutout. In Extrude command, there is no option allowing you to generate two separate bodies in one operation. There are several ways to do this. The quickest one would be creating an extrusion as a separate body. Then use Combine command -> pick the newly created solid as the Base and pick the old solid as Toolbody -> Intersect -> check "Keep toolbody" option -> OK. Then the old solid will be invisible. Just turn the visibility back on.
Or, you can extrude the profile as a surface. Then add a boundary patch surface and stitch them together. Next, use Split command to separate the solid.
Thanks!
When you cut out that doorway, what if you were to instead of removing the entire opening, simply do a thin wall cut around the door representing the gap. Then you would have two seperate bodies in your model. It wouldn't show up in the browser as 2 bodies, but not sure this would work for what you are trying to do. If you are looking to create an assembly out of this, you could then insert this part into an assembly, insert a blank part into the assembly and create a top down by using the existing edges of the outer shell (editing it within the assembly) to create your door by revolving the profile.
I know this probably sounds confusing, but if you insert your part in this thread, I will look at it and show you what I am talking about.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
