Solved by ChrisMitchell01. Go to Solution.
To address this, you need to first install the service pack 2:
Then apply the subsequent update4 from :
This is the page you're looking for, in particular the section about running the command line in the command prompt:
The operations team are still trying to address the broken links.
Sorry !
-Chris
Edited by
Discussion_Admin
I have experienced the same problem and I found that the windows upgrade from 8 to 8.1 was where the problem starts.
By returning to 8.0 and installing the fix packages I can now reusing Installer 2013 but it operates at a very slow pace and only with drawings I complete on my computer. If I begin a project on another computer and try to open it on my computer it will freeze.
Has anyone any suggestions please?
Diver2994
Inventor 2013 Is not fully supported on Windows 8 or 8.1. (i.e. use at your own risk, the service packs help but you still encounter issues.)
Inventor 2014 "works" with windows 8 and 8.1 (but runs much better on windows 7, IMO)
and
Inventor 2015 works with 7, 8, and 8.1 (runs smooth on these OS)
See the System requirements page for inventor.
For 2013
For 2015
Note: In 2015, win XP is no longer supported
I hope this helps,
James
Inventor back to version 2012 is fully supported on win8 & win8.1. You simply need to ensure you are using the latest service packs & updates.
Since 2013 is most recently mentioned below, please see http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/update-6-fo...
...so you need to
Chris
I'm happy to be wrong in this case,
You guys should update the system requirements page to reflect the updates 🙂
James
I've had the same problem. Upgrade from win 8 to win 8.1, getting 0xc000142 error for starting the program.
Now reading Cris' instructions: Install Inventor 2013 SP 2, 64 bit and Update 6; using the links mentioned.
After installation everything just works perfect and Inventor 2013 Pro just run again.
I think I will just jump over the Atlantic to give yor a pat on the shoulder.
Thank You
Søren
Aarhus, Denmark
