Inventor General Discussion
nmetzger
Message 1 of 5 (460 Views)
Inventor Prof 2013 Saving Flat View
460 Views, 4 Replies
10-16-2012 11:59 AM
 I have a drawing a customer sent in a formed view. I created a flat view of the part, but I cannot save it in the flat view. What do I need to do? It keeps giving me a dialog box that says I can't save it in a flat view... search says I should be able to save it as a .dwg or .dxf etc. Help
Curtis_Waguespack
Message 2 of 5 (455 Views)
Re: Inventor Prof 2013 Saving Flat View
10-16-2012 12:04 PM in reply to: nmetzger
Hi nmetzger,
Activate the Flat Pattern, then right click on it in the graphics window and choose Export Face As,  then choose DXF or DWG.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
JDMather
Message 3 of 5 (435 Views)
10-16-2012 01:01 PM in reply to: nmetzger
There are 3 ways to do this (each returning slightly different results), the first is to right click on the face of the flat pattern as Curtis suggested.  Other techniques are to right click on the Flat Pattern browser node or place Flat Pattern view in idw or dwg, depending on what you need.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
nmetzger
Message 4 of 5 (431 Views)
10-16-2012 01:06 PM in reply to: JDMather
Thank you, I will try that as well. I did get it exported to a .dxf, only problem now is I have to convert it to an older version of CAD. I am the only one in my company with the 2013 Inventor Suite and there seems to be an issue with opening my drawings with CAD LT 2011. I did not think that would be a problem... Nichole Metzger Manufacturing Engineer Valco Industries 625 Burt Street Springfield, Ohio 45505 937-399-7400
JDMather
Message 5 of 5 (425 Views)
10-16-2012 01:21 PM in reply to: nmetzger
One of those saving Options also allows setting version of dwg
or
use free DWG TrueView to convert.
or
use free Inventor Fusion to convert.
