Inventor Forum
Inventor Product Design Suite Ultimate 2013
2 REPLIES 2
KevinPinks7697
261 Views, 2 Replies
I am trying to find out why AutoCAD 2013 is not working. If I click on the program in the start menu it tells me to run setup.exe for AutoCAD Mechanical 2013. So I insert the stick, and it tells me that AutoCAD Mechanical 2013 is already installed? I cannot see any sort of "repair" option?
2 REPLIES 2
Did an Icon show up on the desktop ..or if you go to the start menu ..do you see an Autodesk 2013 Folder? If you have all of these ..can you go to the icon and say Run as Admin..will it then start?
Mike Davis
Thanks for your help. I eventually got it to work by performing a repair on the install.
