Inventor Forum
Inventor Pro 2014 Not Responding on Create New
15 REPLIES 15
Message 1 of 16
kaedenradde
1941 Views, 15 Replies
I'm sure I'm not the only one with this problem, but a few days ago, Inventor was working just fine, then out of nowhere, when I go to click on "New" it freezes, and gives me the "Not Responding" message. I have tried completely uninstalling the program, re-installing. Nothing has worked. I also have Service Pack 1, and the Update for Service Pack 1 installed, neither of which have fixed the issue. Any and all help would be greatly appreciated. I am also running Windows 8.1, but it was working fine even after the install of Windows 8.1, this has just suddenly happened.
Thanks!
15 REPLIES 15
Message 2 of 16
Hi kaedenradde,
If you go to the Tools tab > Application Options button > Hardware tab, does changing the setting to Compatiblity or something else improve things?
http://help.autodesk.com/cloudhelp/2014/ENU/Inventor/files/GUID-F39A7D5F-86E5-4F48-9313-8303E9A799BA...
I hope this helps.
Curtis
Message 3 of 16
blair
in reply to: Curtis_Waguespack
Possibly a bad user profile, can you try logging in as a different user. If that works I will then supply you with instructions on how to re-set your user profiles.
Delta Tau Chi ΔΤΧ
Message 4 of 16
kaedenradde
in reply to: blair
Blair,
I tried running the program, and creating a new part under the Guest account, and it worked just fine, so it must be something similar to what you described! Could you help me with the rest?
Thanks!
Message 5 of 16
blair
in reply to: kaedenradde
Resetting an Inventor User’s Local Environment Issue: Inventor used to work and now it or parts seem to have an issue. Solution: We have found that fully resetting the users environment will force Inventor to rebuild the users environment from scratch resolves many of these type of issues. The steps are as follows (Please substitute as appropriate for your version): 1. Exit Inventor 2. Open Regedit 3. Rename a. HKEY_CURRENT_USER\Software\Autodesk\Inventor\Current Version b. HKEY_CURRENT_USER\Software\Autodesk\Inventor\Current Version.org 4. Rename a. HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion0.0 b. HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion0.0.org 5. Rename a. HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion18.0 b. HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion18.0.org 6. Exit Regedit 7. Rename a. C:\Users\USERID\AppData\Local\Autodesk\Inventor 2014 b. C:\Users\USERID\AppData\Local\Autodesk\Inventor 2014.org 8. Rename a. C:\Users\hollanb\AppData\Roaming\Autodesk\Inventor 2014 b. C:\Users\hollanb\AppData\Roaming\Autodesk\Inventor 2014.org 9. Start Inventor and test. Note: RegistryVersion18.0 = Inventor Release 2014 RegistryVersion17.0 = Inventor Release 2013 RegistryVersion16.0 = Inventor Release 2012 RegistryVersion15.0 = Inventor Release 2011 RegistryVersion14.0 = Inventor Release 2010
Delta Tau Chi ΔΤΧ
Message 6 of 16
in reply to: blair
Hi
I have been having this same problem. I have created a new profile and signed in but still the programme does not respond. I am totally out of ideas. Any help would be much appreciated
Message 7 of 16
biggietee6
I am having similar issues, except when i select the drop down menu, nothing from their will launch, i.e. I can not select create new, open, or if i have a file open then i can not export. To clarify I can click the menu to drop down, but when I click open/new/export etc. its almost as if it is a blank button and has no action
Message 8 of 16
blair
in reply to: biggietee6
Try the new/different user profile and see if this solves the problem. If so you may need to repair your profile as well. If it does, I posted the setting a couple of threads earlier on this post.
Delta Tau Chi ΔΤΧ
Message 9 of 16
biggietee6
in reply to: blair
Okay, I am not able to follow your post. First off what is regedit and secondly on the path files how do you rename those? Also, I am not able to locate that path, I am stuck at USERID (which is my user name for the computer I assume; like yours is hollanb, correct?) I see no app data in that folder.
Please let me know how to continue, because when i created guest profile problem was solved
Message 10 of 16
biggietee6
figured out the registry, but still stuck on the file path for the c drive. Thanks
Message 11 of 16
blair
What exactly is the problem with the c-drive path. Most of Inventor should be defined by your project files. The rest as to where Inventor looks for its own files such as templates are in the Application Options within Inventor
Sent from my iPad
Delta Tau Chi ΔΤΧ
Message 12 of 16
biggietee6
in reply to: blair
This is the step where I am stuck; you are saying to rename this drive, and I can not locate it with the defined path you give. Is there another way to find this location or am i looking in the wrong place? 7. Rename a. C:\Users\USERID\AppData\Local\Autodesk\Inventor 2014 b. C:\Users\USERID\AppData\Local\Autodesk\Inventor 2014.org 8. Rename a. C:\Users\hollanb\AppData\Roaming\Autodesk\Inventor 2014 b. C:\Users\hollanb\AppData\Roaming\Autodesk\Inventor 2014.org
Message 13 of 16
biggietee6
I am using Windows 8.1, I found the file path under C:\users\public\public documents\autodesk\inventor 2014.. I assume this is different since you were using windows 7.. Anyway's many thanks!
Message 14 of 16
in reply to: blair
Got same issue here with drop down Menu. Logged in as other user works fine.
Tried reseeting user environment as per your suggestions. Still have no reponse to any "I pro" menu items.
Any thing else I could try ??
Tnx MRB
Message 15 of 16
blair
Have you installed all the SP's and patches for your product. Link is at the bottom of this web-page (Service Packs & updates). After you have done that, RMB on the Inventor Icon and select the "Run as Administrator" option.
Delta Tau Chi ΔΤΧ
Message 16 of 16
in reply to: blair
I found the issue..
Jeez really...
I customised my fount size to 110% because my eyes aren't as good as they used to be......
This for some reason hides the tasks performed on the drop down menu..
Put the font back 100% & everything now works agaiin.
