Inventor Forum
Inventor Parametric Dimensioning- Power Relationshipc
4 REPLIES 4
beemurfee
369 Views, 4 Replies
Hi there,
I am creating a sketch and my first horizontal called x is 2in away from the neutral axis as seen in the picture. I now want to create a second line that is parallel to the x line but is x^2inches away (4 inches) from the neutral axis.
When I enter the formula
(x)^2 ul
I get 10.16 instead of 4
However if I enter
((( x ) * ( ( ( 1 ul ) / ( 1 in ) ) )) ^ ( 2 ul ) ) * ( ( 1 in ) / ( 1 ul ) )
Which converts it to ul (unitless units) and then back into inches it works????
Why won't the first way work, and is there a simpler way to do power functions in inventor? I can't find anything on this...
4 REPLIES 4
blair
in reply to: beemurfee
I would get ride of the "ul" at the end: http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-69D04C7D-E195-49C0-B1B2-03C88A806D9D
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
rhasell
Hi
Try the Isolate parameter.
Isolate link
'edit' LOL, Blair, just noticed we linked to the same place.
Reg
2024.2
Please Accept as a solution / Kudos
JDMather
Cancel out unit so you don't end up with unit^2, then multiply by 1unit.
beemurfee
Thank you very much!!! These are all great solutions that solved this problem
