Hi there,
I am creating a sketch and my first horizontal called x is 2in away from the neutral axis as seen in the picture. I now want to create a second line that is parallel to the x line but is x^2inches away (4 inches) from the neutral axis.
When I enter the formula
(x)^2 ul
I get 10.16 instead of 4
However if I enter
((( x ) * ( ( ( 1 ul ) / ( 1 in ) ) )) ^ ( 2 ul ) ) * ( ( 1 in ) / ( 1 ul ) )
Which converts it to ul (unitless units) and then back into inches it works????
Why won't the first way work, and is there a simpler way to do power functions in inventor? I can't find anything on this...
Solved by JDMather. Go to Solution.
Hi
Try the Isolate parameter.
'edit' LOL, Blair, just noticed we linked to the same place.
Cancel out unit so you don't end up with unit^2, then multiply by 1unit.
