The transition is complete for the Inventor R2014 help!
Thank you for your patience as we transitioned from the Autodesk Wiki online Help pages to the new Autodesk online Help environment, Autodesk Knowledge Network (AKN). You should enjoy improved performance and search options, along with a fresh new look here: http://help.autodesk.com/view/INVNTOR/2014/ENU/.
You will be redirected automatically to AKN and the Inventor 2014 help when you access Help from within:
The AKN help is available in English only at this time.
We are excited to bring , Autodesk Knowledge Network (AKN)to you and we look forward to your participation and comments.
Please let me know of any questions,
Thank you,
Jeanie Wayker
Finally. I hope you can direct me to help. It doeas not deal with AKN.
I was not able to find out how to post a question - just what to put in one.
I want to convert aq STL file to a STL solid for 3D printing.
I've installed 'Mesh Enabler'.
I followed
http://grabcad.com/questions/tutorial-convert-stl-mesh-to-solid-file-in-autodesk-inventor .
Did the 'Convert to Base Feture', a ipt file was made ansd saved.
Butit does not appear solid and I am not able to save as stl.
Can you help or difrect me to help?
I have just installed Inventor 2014 across 11 workstations using a deployment. When I click the 'Help' button, a web browser opens with:
Autodesk Inventor 2014 Help
The Help for this Autodesk product is now online and is being continuously updated. To access the online help you must be connected to the internet.
To access the Inventor 2014 Help when you are offline, you must download the Inventor 2014 local help. To download, access the internet and download from here:http://autodesk.com/inventor-2014-help-download
What do I do to access the online 'help'
Ian Solomon
I require assistance on treansfering a .dwg file (CAD) to a .itp (Inventor Part) can you guys please help???
Welcome to the forum,
Not sure what your part looks like, but there is no directway to create an Inventor part (.ipt) from an Autocad drawing (.dwg)
You can copy and past the drawing sketches into an Inventor sketch to protrude or revolve, but that is about it.
FYI, it would be better next time to start your own thread instead of piggy backing an existing one.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Ray,
Did you get an answer to your issue? If not, post a link to your thread here and I will take a look at it.
Please try again. Please make sure you are online - When you click help in R2014 and you are online you should be directed to this page:
Let me know if you are accessing the help now.
Thank you,
Jeanie
@jeanie.wayker wrote:Please try again. Please make sure you are online - When you click help in R2014 and you are online you should be directed to this page:
Thank you,
Jeanie
Or if you click help in 2013 ... and (I'm told) in 2012 as well ...
When will the correct help files for the earlier versions - for those of us whose companies prefer to stay a little behind - come back?
Rusty
I have installed the local help files. That is all that I have. It doesn't matter whether I am online or not, I only get the local help files.
Access C:\Program Files\Autodesk\Inventor 2014\Bin\helpids.xml and ensure the UseOnline value is set to ‘0’ - when set to '0' the ONLINE help will launch when you are online.
when set to '1' the LOCAL help will launch even when you are online.
Let me know if this resolves the issue.
Thank you,
Jeanie
We apologize for this inconvenience but due to the transistion to the Autodesk Knowledge Network -
If you want to access the online help, You will be redirected automatically to AKN and the Inventor 2014 help when you access Help from within:
If you want the R2013 Help, you can download http://autodesk.com/inventor-2013-help-download, follow these instructions to always access the local help even when you are online:
After installing, if you always want to access the local help from within Inventor:
Thank you, and again, we do apologize for this inconvenience.
Jeanie
You can find these instructions here:
Indeed!!! Loud and clear! Loud and clear, my friend!!!!
Thank YOU!
Jeanie
@jeanie.wayker wrote:We apologize for this inconvenience but due to the transistion to the Autodesk Knowledge Network -
- Inventor 2014
- Inventor 2013
- Inventor 2012
- Access C:\Program Files\Autodesk\Inventor 2014\Bin\helpids.xml and ensure the UseOnline value is set to ‘1’ as follows: UseOnline="1". If the value is set to ‘0’, change the value to ‘1’.
- Run regedit.exe
- Access HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Inventor\RegistryVersion18 .0
- Double-click EnableOnlineHelp
- Change the Value Data field to 0.
Jeanie
I love Autodesk as much as anyone, but I really feel like I have to say something here ... For $10,000 (I have PDS Ultimate) I should have a fully-functional piece of software. I understand that there's bugs on release, and they get fixed - and I'm very patient with that sort of thing - but I shouldn't have to be doing manual registry edits to make the help files work.
Why couldn't you have left the <2013 stuff the way it was, and then moved 2014 over to AKN? Is the price of hard drive space in San Francisco that much higher than Fresno?
Rusty
I really do appreciate your feedback. We do apologize the transition to the new learning environment caused so many problems. I am sharing your feedback with others and we continue to earnestly try to resolve these types of issues.
Thank you again,
Jeanie
