Inventor Forum
Inventor ONLINE help is now live on Autodesk Knowledge Network (AKN)
54 REPLIES 54
Message 1 of 55
jeanie.wayker
4321 Views, 54 Replies
The transition is complete for the Inventor R2014 help!
Thank you for your patience as we transitioned  from the Autodesk Wiki online Help pages to the new Autodesk online Help environment, Autodesk Knowledge Network (AKN). You should enjoy improved performance and search options, along with a fresh new look here: http://help.autodesk.com/view/INVNTOR/2014/ENU/.
You will be redirected automatically to AKN and the Inventor 2014 help  when you access Help from within:
  • Inventor 2014
  • Inventor 2013
  • Inventor 2012
The AKN help is available in English only at this time.
We are excited to bring , Autodesk Knowledge Network (AKN)to you and we look forward to your participation and comments.
Please let me know of any questions,
Thank you,
Jeanie Wayker
54 REPLIES 54
Message 21 of 55
in reply to: jeanie.wayker
Jeanie:
That link is for help files to be installed with inventor, they are not a stand alone help. I am giving up searching for help here. Wish wikihelp had been allowed to stand until a replacement was ready. That was a big mistake.
Kieran
Message 22 of 55
Ray_P
One thing online help does not cover: Is there a way to mirror an I-part in the part factory environment? I have posted this and no one has touched it in the last year.
Message 23 of 55
Ray_P
in reply to: Curtis_Waguespack
Hello do you know of a way to mirror an I-part in the part factory table. I have searched and tried and sure would be nice. When a left hand part is required in a model there is not an easy way to accomplish this task I have recently found that if I derive in the parent factory part rather than the child component I can get better results. I set the parent part to desired configuration and update and suppress link in the mirror part. This works well but to create an I-Factory assembly it is not feasible as I cannot use table replace. Any help would be greatly appreciated. Thanks
Message 24 of 55
Finally. I hope you can direct me to help. It doeas not deal with AKN.
I was not able to find out how to post a question - just what to put in one.
I want to convert aq STL file to a STL solid for 3D printing.
I've installed 'Mesh Enabler'.
I followed
http://grabcad.com/questions/tutorial-convert-stl-mesh-to-solid-file-in-autodesk-inventor .
Did the 'Convert to Base Feture', a ipt file was made ansd saved.
Butit does not appear solid and I am not able to save as stl.
Can you help or difrect me to help?
Message 25 of 55
Ray_P
in reply to: Ray_P
The reason I have posted here is because obviously I cant get a response to my issue in the discussion group or wiki help. Thanks
Message 26 of 55
ian.solomon
I have just installed Inventor 2014 across 11 workstations using a deployment. When I click the 'Help' button, a web browser opens with:
Autodesk Inventor 2014 Help
The Help for this Autodesk product is now online and is being continuously updated. To access the online help you must be connected to the internet.
To access the Inventor 2014 Help when you are offline, you must download the Inventor 2014 local help. To download, access the internet and download from here:http://autodesk.com/inventor-2014-help-download
What do I do to access the online 'help'
Ian Solomon
Message 27 of 55
calderona45
I require assistance on treansfering a .dwg file (CAD) to a .itp (Inventor Part) can you guys please help???
Message 28 of 55
Cadmanto
Welcome to the forum,
Not sure what your part looks like, but there is no directway to create an Inventor part (.ipt) from an Autocad drawing (.dwg)
You can copy and past the drawing sketches into an Inventor sketch to protrude or revolve, but that is about it.
FYI, it would be better next time to start your own thread instead of piggy backing an existing one. Smiley Happy
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 29 of 55
Cadmanto
in reply to: Ray_P
Ray,
Did you get an answer to your issue?  If not, post a link to your thread here and I will take a look at it.
Best Regards,
Scott McFadden
Message 30 of 55
mrattray
in reply to: Cadmanto
You can translate the data directly, if the dwg contains a solid model. However, I've never had much success with it. If you are talking about 3D data then your best bet is to export it to a sat file and import that. If it's 2D data, then Scott is right. Your best bet is to recreate the part in Inventor from scratch. Can you give us anymore information about your problem?
Mike (not Matt) Rattray
Message 31 of 55
jeanie.wayker
in reply to: ian.solomon
Please try again. Please make sure you are online - When you click help in R2014 and you are online you should be directed to this page:
Let me know if you are accessing the help now.
Thank you,
Jeanie
Message 32 of 55
LT.Rusty
Thank you,
Jeanie
Or if you click help in 2013 ... and (I'm told) in 2012 as well ...
When will the correct help files for the earlier versions - for those of us whose companies prefer to stay a little behind - come back?
Rusty
Message 33 of 55
ian.solomon
I have installed the local help files. That is all that I have. It doesn't matter whether I am online or not, I only get the local help files.
Message 34 of 55
jeanie.wayker
Please see http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/download-an...
Access C:\Program Files\Autodesk\Inventor 2014\Bin\helpids.xml and ensure the UseOnline value is set to ‘0’ - when set to '0' the ONLINE help will launch when you are online.
when set to '1' the LOCAL help will launch even when you are online.
Let me know if this resolves the issue.
Thank you,
Jeanie
Message 35 of 55
jeanie.wayker
in reply to: LT.Rusty
We apologize for this inconvenience but due to the transistion to the Autodesk Knowledge Network -
If you want to access the online help, You will be redirected automatically to AKN and the Inventor 2014 help  when you access Help from within:
  • Inventor 2014
  • Inventor 2013
  • Inventor 2012
If you want the R2013 Help, you can download http://autodesk.com/inventor-2013-help-download, follow these instructions to always access the local help even when you are online:
 After installing, if you always want to access the local help from within Inventor:
  1. Access C:\Program Files\Autodesk\Inventor 2014\Bin\helpids.xml and ensure the UseOnline value is set to ‘1’ as follows: UseOnline="1". If the value is set to ‘0’, change the value to ‘1’.
  2. Run regedit.exe
  3. Access HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Inventor\RegistryVersion18 .0
  4. Double-click EnableOnlineHelp
  5. Change the Value Data field to 0.
Thank you, and again, we do apologize for this inconvenience.
Jeanie
You can find these instructions here:
Message 36 of 55
mrattray
Perhaps this should be a real setting (available in the GUI)?
Message 37 of 55
jeanie.wayker
in reply to: mrattray
Indeed!!! Loud and clear! Loud and clear, my friend!!!!
Thank YOU!
Jeanie
Message 38 of 55
LT.Rusty
  • Inventor 2014
  • Inventor 2013
  • Inventor 2012
  2. Run regedit.exe
Jeanie
I love Autodesk as much as anyone, but I really feel like I have to say something here ...  For $10,000 (I have PDS Ultimate) I should have a fully-functional piece of software.  I understand that there's bugs on release, and they get fixed - and I'm very patient with that sort of thing - but I shouldn't have to be doing manual registry edits to make the help files work.
Why couldn't you have left the <2013 stuff the way it was, and then moved 2014 over to AKN?  Is the price of hard drive space in San Francisco that much higher than Fresno?
Rusty
Message 39 of 55
jeanie.wayker
I really do appreciate your feedback. We do apologize the transition to the new learning environment caused so many problems. I am sharing your feedback with others and we continue to earnestly try to resolve these types of issues.
Thank you again,
Jeanie
Message 40 of 55
Ray_P
Please remove me from this thread only. I keep getting updates from you.I have tried to weed through my settings to find out why & I can't seem to shake this thread.
Raymond E. Price
Point Eight Power
Mechanical Design Team
(504)394-6100
direct: (504)391-6808
fax: (504)391-6804
www.PointEightPower.com
We listen, we apply intelligence, and we respond. Every time.
