The transition is complete for the Inventor R2014 help!
Thank you for your patience as we transitioned from the Autodesk Wiki online Help pages to the new Autodesk online Help environment, Autodesk Knowledge Network (AKN). You should enjoy improved performance and search options, along with a fresh new look here: http://help.autodesk.com/view/INVNTOR/2014/ENU/.
You will be redirected automatically to AKN and the Inventor 2014 help when you access Help from within:
The AKN help is available in English only at this time.
We are excited to bring , Autodesk Knowledge Network (AKN)to you and we look forward to your participation and comments.
Please let me know of any questions,
Thank you,
Jeanie Wayker
Thanks Jeanie for your hard work on this.
Looks good so far.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Thank you for your comments and question. I do not have a definitive answer whether there will be a replacement help system for non-current versions(2013&2012)?
I am lookng into that and will let you know.
Thank you again,
Jeanie Wayker
I have to say, not having dived into the new help too deep yet, still being on 2012, having the back versions would be of great help.
I would have to agree on th eolder versions, but being on 2013... 2014 isn't that much of a stretch. most questions I have with 2013 SHOULD be covered in 2014.
Thanks for the hard work, I know some of us were a bit impatient.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thank you for your feedback and your question. Yes, Autodesk will be launching the 2013, 2012 versions of the help later this year and we will keep you updated on when they go live. Redirecting these non-current versions to 2014 content is a temporary solution to ensure that you have content to reference until that occurs. Your feedback on videos and browser pane has also been noted and is under consideration.
Looks great, now if we could just get some of the posters to look and read the help before they post (even do a search on their problem before they post).
@jeanie.wayker wrote:
... Autodesk will be launching the 2013, 2012 versions of the help later this year ...
Until the new AKN versions go live, it might be helpful for users to go to these links to download the help files for their version and set them to be accessed locally on their computer or network:
To download the complete Inventor 2012 Help System to your computer or local network for installation, click here:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=18715627
Be sure and set the registry switch as described here:
http://images.autodesk.com/adsk/files/installing_autodesk_inventor_full_help_2012.htm
To download the complete Inventor 2013 Help System to your computer or local network for installation, click here:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=21310054
http://images.autodesk.com/adsk/files/help_install_instructions_inventor.html
I hope this helps.
Curtis
Curtis,
If you noticed I had this thread pinned to the top of this forum.
That will not only make it easier for users to get to this thread, but to the links you provided as well.
Thank you for placing them here.
It is the wee hours of Nov 9. I start a new job on Nov 11 for an employer using Inventor 2013. The wiki help was sensibly indexed a year and a half ago to learn how to perform operations. Is there any resource available for me to reveiw using inventor 2013 this weekend?
Steve,
Welcome to the forum.
If you notice there is a posting from Curtis that gives a link to the 2013 help online.
I goes here http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=21310054
but follow his instructions.
Cadmanto:
Thanks, but that link is for help files to add to installed versions of Inventor. I am at home. My new employer has inventor 2013 at their place of business. I need to study this at home over the next two days. The old Wikihelp allowed reading instructions and viewing films.
I am sorry that this link cannot help you. What version did you last use?
Or do you have no Inventor experience at all?
If you have none at all, then I would go to youtube and start with simple videos on simple operations.
Also, I know you are going to be using 2013, but looking at the 2014 help isn't going to be that much different.
If you google search for whats new in 2013 and then for 2014 you will have a pretty good idea of what you are not going to see.
Great Solution 😞
In the past I save a lot of interesting pages as .MHT,
If I do this now I will get only empty pages.
Where is the Save as PDF functionality
The most of the links you will find with Google didn't work any longer
This is truly a helpfully
GOOD JOB, well done
my 2 cent
Hi, You can download the Inventor R2013 help to your local computer from here: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=21310054
Althought the online help currently available is for R2014, this should still be an excellent resource for you.
I am so excited for you.
I hope these are good resources for you.Please keep us posted on your progress.
Jeanie Wayker
Let me try that again!!!
Although the online help currently available is for R2014, this should still be an excellent resource for you.
I really am so excited for you.
Jeanie Wayker
