Hi!
I was trying to install AutoCAD Inventor Suite 2013 LT Trial (x64) on Windows 8 RP yesterday when installation failed. I don't have the log now but the reason was .NET 4 or its language pack. dotNET 4 is a part of Windows 8 now, so any workaround?
Solved by stephengibson76. Go to Solution.
Thanks, it works now.
I have installed everything in Inventor Suite LT 2013 and does work. However, both Inventor and Autocad are very unstable, I've got two access violation error message within 10 minutes. Doing real work in such circumstances is really a pain in the ****. Based on what 2013 versions doing, I won't bet on older versions.
BTW I attached my setup.ini. I have deleted all DOTNET prerequisition. I didn't delete DOTNET sections between the begin and end comments because it ended in "missing DOTNET20 line" (os something like this) error message, so I deleted the prerequisition only.
i have installed autodesk inventor professional 2013 on windows 8 , there is no problem with the installation proccess and finish well. but when i try to go to mold design environment the ribbon tab is not appear. i have checked the add ins manager and i saw it loaded.
please help to solve this issue ,
thanks
Hello
I installed Autocad InventorLT 2013 on a new computer that is currently running Windows 8.1.
I can open the Autocad LT, DWGand the Sketchbook programs. But the Inventor LT program does not start. CGive a (0xc0000142) error, Or "the application was unable to start. I tried running in Compatability mod Windows 7. No luck. Uninstalled and reinstalled same thing.
Any suggestions?
Chuck
CB Duffeck
