When I open Inventor, the message "cannot load..." pop-out. Although I still can create the 3D model in Inventor but everytime when I open my existing or new drawing file (.idw), Inventor will occur fatal error and closed.
Anyone can advise me or help me to solve my problem?
Thanks in advance.
Solved by ConnieYong. Go to Solution.
Welcome to the forums!
The error message states that it is unable to load a specific file. I would start by searching your folders for that file, and if you find it move it back to that folder listed in the error. If you cannot find it (it may have been accidentally deleted?), you may have to reinstall or repair your installation.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
After uninstall and reinstall inventor, my problem solved. Repair doesn't help.
