Inventor Forum
Inventor not closing all files - bug?
5 REPLIES 5
382 Views, 5 Replies
As per the subject, this is the second time in 24hrs it has happened.
In the bottom right corner there is still a 1 (and a zero to the left of it in the other box)
As there is still a file open I have to close and re-open inventor before I can change projects.
How can I track what file is not being closed?
What is causing this problem?
5 REPLIES 5
SBix26
What version of Inventor?  What happens if you open a file in the current project and then close it?  I have had occasions in all recent versions of Inventor where I was not able to change projects even though there were no open files, typically when I used Undo to undo a file open step.  I cannot recall noticing the file counter, though.  But in those cases, opening and then closing a file took care of the problem.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
cbenner
I suspect it is more of an issue of a "memory leak".  I've seen before where all files have been closed, and for whatever reason Inventor does not let go of all of the memory it was using.  I've seen this in other CAD systems as well.  Pro E (Creo) was notorius for it and it led eventually to a lot of crashing.  I find that if I am opening and closing a lot of (especially) large assemblies... eventually the safe thing for me to do is shut down and restart Inventor.  It takes a few minutes, but is better than a CTD.  I can usually tell when it is coming, Inventor will start to act... squirrely is the best word.  For me... when in doubt, save and shut down.
I don't know if this is hardware or software related, or if I'm full of hokum... but this is what I suspect is going on.  IT seems to support my theory, here at least.
in reply to: SBix26
Currently running IV2013 SP1.1 on Win7 (fully updated)
I'm fairly sure this was not undo related but I'll certainly pay more attention to that now.
I tried opening and closing a file from the current project, it still did not release the ghost file though.
edit: maybe could be memory related, I know the second time it happened I had been working with a ridiculously complicated file (~200MB .ipt, dodgy conversion from a tekla structures model)
scottmoyse
we've seen this kind of issue before. But it's generally only after running a VB macro, so we wrote a utility to force close all the files in the background. We don't use it anymore, since we moved to 64bit add-ins and it doesn't seem to be an issue anymore. In addition its fairly quick to restart Inventor now we are using SSD's.
If you are interested I can see if I can sort some code out for you
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
in reply to: scottmoyse
Thanks for the offer but at this point I'll say it is not needed.
It's not a huge issue for me (yet)...
