Ive downloaded the free trial of inventor 2014. Its been a week and not yet been able to use it once. Uninstalled and reinstalled 6 times. Please help. Everything downloads fine. I open it and go to the tutural (how to make a box). I open the file and click 2d image. Nothing comes up on the screen. But when I roll the mouse over the area, the values appear in box's. Im literally blind.
Im really keen to learn this and give it a good go. But my trial period is running out really fast. And I have nothing to show but stress wrinkles :).
Solved by JDMather. Go to Solution.
Looks like a graphics card/driver problem in your machine.
Select the plane in the browser to start new sketch rather than in the graphics window.
(try updating your graphics driver or go to Tools>Application Options>Hardware tab and set to lowest setting)
Welcome to the forum.
Make sure you check out the tutorials as well to help you learn the software.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
It appears from the screen shot that the OP is attempting to do a tutorial.
I never looked that deeply. I guess I should have put my specs on first.
Thank you so very much guys.. Ive been wracking my brain for ages. It turns out it was a driver problem. I really really appreciate your help. Now, is there anyway to restart the trial period? Because Ive wasted alot of time.
If you are a student you can get a free 3-yr license here http://www.autodesk.com/edcommunity
