Put all of the memory you can in your server. Microsoft developed the
"/3GB" option for servers. On a server, memory is used to provide multiple
users faster access to their files. The server tries to read ahead and
anticipate the file access by the clients.
I also recommend
A server OS
If you use EIDE disk drives go for big fast ones, and a motherboard that
supports them.
Talk with the professionals at Dell or somewhere as to a good configuration.
Please do not run Inventor on your server. Inventor is designed to use 100%
CPU cycles. This gives file sharing second (and last) priority. The
connections then time out.
John Elliott
"Brian Corbin" wrote in message
news:91D83D20D9D94A84A23F8F72ACD246D4@in.WebX.maYIadrTaRb...
> Guys,
> We are moving the design dept here, and have a chance to setup a new files
> system and knowing how fussy Inv can be I thought a few questions may be
> prudent here. We have some crashes here which we feel are network related
as
> we are running thru about 3 switches onto the same congested server that
> gets used for everything else in the company.
> Our suggestion was to setup a dedicated CAD server just for storing our
> files with gigabit ethernet. The network guy here complains that we would
> bring the network to its kness by having a gigabit network connection and
> leeching all the avaliable network traffic. Also the cost of a new server
is
> always an issue.
> I sorta felt that an INV server probably could just be a mid range desktop
> machine with a couple of 10k Western dig IDE drives in a raid0 config. If
it
> is just a file server it wont need fast garphics or CPU or lots of ram
etc,
> is this correct? (was thinkng of a P4 with 512meg ram and onboard graphics
> would do it?) Also we could run gigabit between our CAD stations and the
> server then run 100mbit for the CAD server onto the network to solve the
> leeching problem.
> Does anyone have a bit more knowledge or experience to share here?
> Some ammo to go back with would be great
> Brian Corbin
