I have an assembly created with inventor, but I want to create a SIMPLE injection mold for it with just a few fasteners on the inside. I'm very new to inventor and the mold design tools make a very complex mold I cannot 3D print. Is there a way to make a very simple mold using mold design or is there a way to use the derive commands to make the 2 piece mold? Thanks.
Solved by JDMather. Go to Solution.
Attach your file here.
The mold design tools can be used to make the most simple mold possible.
You could also use the Derive command - but that is going to do exactly the same thing with more work.
Did you even get the mold design tools to work?
http://forums.autodesk.com/t5/Autodesk-Inventor/Mold-Design-Assembly-UI/td-p/3770435
No, I never got it to work, but I want to determine if I even need it (I'm going to try with inventor 2012 later on) for basic molds. Here is the file...
You can easily create this within a single part file or with a Derived Component.
You do not have draft and some are your sketches are not constrained.
You have not used obvious symmetry about the origin planes (which would take less work).
I tried to post attachment - but my internet connection has been very slow all day.
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Are you still there?
Here is how I might model the part and mold (note: only really need one side as they are symmetrical).
I did not include draft on part for removal from mold. (see attached ipt file) You would then go to Manage tab>Make Components to push out the mold halves and individual part.
Note that you also had a gap.
Thanks so much for your help. Could you briefly list the steps you took to create the mold using the derive command? Also, how might I be able to add extruding and indenting pegs that can fasten the 2 mold parts?
Method 1 (see attached zip)
Method 2 (see attached zip)
Both of these options are on the Manage tab.
hi,
can you show us an example of molding with a hole? I have difficulty to find correct split tool. a simple xy plane is not enough. thanks.
please see attachment.
inventor 2013 window 7
Use a 2d sketch, and build the cut line in section view.
Then you can use the sketch lines as the cutting tool, the linework will have to be continuous/connected, and extend beyond the part.
T.S.
Oh, thanks. i was using the same method as you suggest.
but I just find out it doesnt work with projected line. no wonder it doesnt work.
@jcneal wrote:
...can you show us an example of molding with a hole?
Are you using Inventor Tooling (Mold.iam). Tooling simplifies the process.
The part in my Vaccuum tutorial shows three different "hole" situations.
A large opening at one end.
A grill.
Fastener Holes.
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%202011%20Tutorial%2014.pdf
A forth situation would be where a sliding side core would be needed.
