Hi everyone!
Has anybody encountered a problem, that Inventor standard libraries are lost?
I was trying to make a frame out of standartized parts, as usual, but the only profile left is flat chamfer.
I checked the libraries, and they all appear 'not available':
Before this I uninstalled my Factory Design Suite, so it probably took something with it.
Is it possible to get the libraries back without reinstalling Inventor?
Solved by lauris. Go to Solution.
If you can get the same version library files(*.idcl) from other guys, you can copy them to your machine(the default folder is showing on your picture).
