Inventor Forum
Inventor is not a toy... or is it?
63 REPLIES 63
Message 1 of 64
981 Views, 63 Replies
See .avi in IVCF, warning - size is 10 megs.
Thought someone would enjoy a little levity for the holidays. This
started as the constraints tutorial on Adsk web site. It worked so
well I decided to keep adding till IV broke. It's not surprising I
ended up with something that looked like a stamping press, complete
with feeder, de-reeler and oil spray. Then I decided to get cute and
add a sailboat to the oil reservoir... that's when it turned into a
toy. No better way to learn than repetition, and I replicated. The
first 5 hours everything was breaking on every move. After I figured
it out, I couldn't believe how easy and solid it was. It's all stock
constraints driven by the blue crank gear. No equations or macros. IV
lasted longer than I did, but it got pretty slow to work with. I'm
thinking IV would be very popular if it sold for $59.00 and was called
Inventor Tycoon. :o)>
63 REPLIES 63
Message 2 of 64
Kudos that was great.
Kathy Johnson
Message 3 of 64
my favorite part is the girl on the trampoline, how did you constrain her chest?
Message 4 of 64
That's great!! Want me to put it on my site?
Sean Dotson, PE
Autodesk Inventor Certified Expert
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Diemaker" wrote in message
news:6n7etvgl13v3iceictip44ataa9ef4g9un@4ax.com...
Message 5 of 64
Excellent! ... Don't think I'd want to crank that saw all day though!
~Larry
Message 6 of 64
Sweet!
Matt
Message 7 of 64
Excellent.
My son would enjoy the whale jumping out of the oil.
Richard
Message 8 of 64
Really interesting... I am amazed how it would animate all at the same
time...
Good job...
Derek Sevier
Mechanical Design Engineer
Quality Corporation
derek dot s at donkeyforklift dot com
www.donkeyforklift.com
Message 9 of 64
How much time did you spent on this?
Message 10 of 64
Bravo
Message 11 of 64
Has your boss seen this?....... you did it all at home right?
JOhn
Message 12 of 64
That is a keeper for sure. Excellent job
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
Autodesk Discussion Forum Moderator Program
Message 13 of 64
EABell
Great job. I love it!
Ed
Message 14 of 64
That is incredible!!!
Message 15 of 64
so will there be a turorial on how to make that.? that thing is extremely
cool to watch
"Thom Rock" wrote in message
news:f1a52f1.12@WebX.maYIadrTaRb...
Message 16 of 64
That is absolutely great. I love the trampoline!
What other software and/or add-ons did you use to do this?
Message 17 of 64
This is very cool. I am going to assume that you used Animator to
create it. If this is the case then you may not have hit Inventor's
limit but rather ran out of memory in Animator. The solution to that is
to break it up into several segments.
Message 18 of 64
The trampoline made me think you used another software, but I figured out
how you did it. Great work.
It looks like you wasted a lot of time playing around, but I'd bet you
learned a ton about IV assemblies and constraints.
Message 19 of 64
lbordian
That was very cool. Excellent job! Leonard
Message 20 of 64
Didn't take long for someone to comment on that. There are 3 little
gears with cranks driven by the red gear with the connector arm. Those
provide the different reciprocating movements that rock things at the
different speeds. ----------
