Inventor Forum
Inventor imperial mold library
5 REPLIES 5
lfriend
1165 Views, 5 Replies
I have recently installed the imperial mold library in IV and I have found that there is not a lot of options when it comes to mold bases, cooling components, and such.  There isn't a single slide in the library.  I don't get it.  Is there a reason?  Do I have the wrong library file? Or do I need to add files to the library?  If so, how?  I guess I expected to have most of the DME catalog readily at hand.Smiley Frustrated
Tags (1)
5 REPLIES 5
BarryZA
in reply to: lfriend
When you say install, do you mean from flash/disk?
the Autodesk website has the full metric and imperial mold library, which you have to download (overnight, huge file) which will give you the full functionality.
In my opinion this feature should be better advertised.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21487506&linkID=9242019
lfriend
I installed the 2014 imperial remote file from the Autodesk website.
BarryZA
lfriend
This is good, but how do I add these files to the libraries?  I can get these files directly from the vendor (in parasolid), but I would like to add them to the library.
BarryZA
I haven't quite done what you are going to do, but in general:
set your project file.
create a new library that will be read/write, you cannot add a part to one on Inv's default libraries as they are read only.
Manage tab - Author - create component (I have only really used structural shape for frame generator profiles)
In the past I could figure out most of what I needed, after I worked out that you need a read/write library.
All I have done with mold components is to copy existing libraries of ejector pins etc. and edit the spreadsheets so that the data matched the sizes and part numbers I am able to get from our supplier.
