DWL is the extension for a locked drawing file in AutoCAD. It sounds
like that file got moved to your desktop and might be sitting on top of
your IV icon. Try moving it to the side and see if IV icon is
underneath. Check the properties of the DWL icon to find out where the
file is located. If I remember correctly, if you try to open the
original file, it will open in read only mode because of the lock file.
If you delete the DWL file you should be able to open the original in
the edit mode.
Was there a proxy message screen when you tried to open the file? If so
it was not created in vanilla AutoCAD and it could be a third party
addon that is causing the problems.
Throuble wrote:
> Here's a strange one for you: I received an AutoCAD drawing from a customer today that gave me some troubles and caused ACAD (2004) to lock up a few times. Well, I got frustrated enough to put this aside, so I shut down AutoCAD and got to work in Inventor.
> After working just a short while, Inventor shut down for no apparent reason, so I went to lunch. When I got back, I noticed that the Inventor icon had been replaced with a file that had the same name as the troublesome ACAD file, but with a file extension of "dwl". Does anyone out there have any clue as to what took place here? I'm stymied!
> Thanks,
> Thom
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4472 w/registry update
Dell UltraSharp 19" LCD
