Inventor General Discussion
Member
djcali
Message 1 of 12 (1,277 Views)
Inventor - How to create a pocket hole
1277 Views, 11 Replies
04-02-2012 10:42 PM
I am basically new to inventor and I would like to get any tips from this forum on how to go about creating a pocket hole like the Kreg Jig. I am a woodworker so this would come in very handy when I am building furniture sketches.
Thanks!
Hi djcali,
Here's a quick step by step for one method (there are several other ways to do this as well).
First create a sketch down the center of the work piece, using an existing origin plane (or by creating your own work plane). Create a line at the correct and angle coming off the center of the work piece, and use a dimension to set the line length. I've dimensioned the line length at 2" but, as long as it goes out past the intersection of the face of the work piece by a bit, the length doesn't really matter.
Next create a work plane on the end of the end of the line by selecting the end point and then the line.
Then create a sketch on this work plane and use the Project Geometry tool to project the line end point into the sketch. You can then either toggle the projected point to be a center point cross, or place a center point cross onto the projected point.
And then finally use the Hole tool to create a hole that goes through all, using the sketch point as the placement.
Attached is an example file as well.
I hope this helps.
Curtis
Contributor jsr
jsr
Message 2 of 12 (1,275 Views)
Re: Inventor - How to create a pocket hole
04-02-2012 11:13 PM in reply to: djcali
Welcome to the forum.
I think the easyest way to do it, would be to creat a plane at the angle you want and make the extrude cut on a sketch you draw up on the plane.
This way you would basicly be working in inventor the same way as you work with the wood and tools in real life.
This is ussurly a good way to make sure that your designs can be done in reality.
Kind Regards
Jens
Inventor Professional 2012
Vault Professional 2012
JDMather
Message 3 of 12 (1,252 Views)
04-03-2012 04:11 AM in reply to: djcali
If you have trouble figuring it out - attach your attempt here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Curtis_Waguespack
Message 4 of 12 (1,226 Views)
04-03-2012 07:33 AM in reply to: djcali
Hi djcali,
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
JDMather
Message 5 of 12 (1,205 Views)
04-03-2012 09:25 AM in reply to: Curtis_Waguespack
or (see attached)
Member
djcali
Message 6 of 12 (1,186 Views)
04-03-2012 10:54 AM in reply to: djcali
I wanted to thank you all for your replies! I will check out the examples when I get back to the shop. I'm so hooked on this program! So as far as reusing this pocket hole once I design it, how is it saved and called back up when I, let's say create a new piece of wood?
JDMather
Message 7 of 12 (1,183 Views)
04-03-2012 11:02 AM in reply to: djcali
You will want to investigate iFeatures.
Member
djcali
Message 8 of 12 (1,176 Views)
04-03-2012 11:24 AM in reply to: djcali
@JDMather Thanks, I'll check into iFeatures
JDMather
Message 9 of 12 (1,167 Views)
04-03-2012 11:46 AM in reply to: djcali
First I recommend you become familiar with doing it the hard way.
iFeatures is an advanced topic.
You might start here  http://home.pct.edu/~jmather/skillsusa%20university.pdf
and then post some examples when you run into trouble or want to see if there might be a better technique.
PaulMunford
Message 10 of 12 (1,122 Views)
04-04-2012 05:44 AM in reply to: JDMather
Great to see another woodworker taking up Inventor!
Here are a couple of posts on iFeatres that you might find useful.
http://cadsetterout.com/inventor-tutorials/ifeatures-primer/
http://cadsetterout.com/inventor-tutorials/what-every-drafter-needs-to-know-about-ifeatures/
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
