I have a situation trying to install Product Design Suite on multiple platforms. In each case, the program hangs when you select the "X" or from the menu. I have tried different media as well as network and non-networked installation.
I only included Inventor, Mechanical, and Vault in the deplotment. Tried to just install Inventor alone as well.
Has anyone experienced this issue? Any ideas?
Solved by DarrenP. Go to Solution.
is this whats happening: http://forums.autodesk.com/t5/Autodesk-Inventor/2012-SP1-Network-Usage/td-p/3261502
DarrenP
